Finding Machinability for an Unknown Material
With an OMAX abrasive waterjet in your shop, sometimes you will come across a new material that has an unknown machinability. Here's how you can determine the proper cutting speed for a new material.
You might also like...
  • Reduce Downtime with System Monitoring Software
    System monitoring software enables you to connect operation controls with machine maintenance and upkeep for increased efficiency and reduced downtime. Programs such as...
  • *Video* Sunkist - Fabrication When You Need It
    Citrus takes a journey from the orchards to your morning glass of orange juice. See how Sunkist's Research and Technical Services division uses a MAXIEM 1530 to...
  • Factors of Speed
    It is often asked "how fast is a waterjet?" OMAX waterjets are faster than many cutting machines on the market. Exactly how fast depends on a number of factors. Power,...
